reverse clutch assy help
Old Jul 11, 2006 | 11:15 PM
83Z28406's Avatar
Car: 83 Z28
Engine: 400
Transmission: Th 350
Axle/Gears: 3.27 9 bolt
Ok to start off my second gear was gone completly so I bought a new wide band and a new reverse input drum a freind and I droped the tranny (700r4) took apart and replaced the band and drum my freind swaped the reverse clutches and piston assy from one drum to the other put it back together and I had no reverse I could hardly push the car while in neutral and engine running then shut off engine pushed easy car goes foward fine in all gears so its back out and I noticed there is not a steele plate between the wavy plate and first friction plate is this correct?
Old Jul 12, 2006 | 11:28 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
they are set up like that from the factory.
check the parts you changed. was there proper clearance for the band? check the sealing rings on the pump. if you cut one of those putting the pump in, it will cause problems with reverse. check hte seal on the reverse input piston, it could have been damaged when changing drums. also, check the seals on the input shaft/drum.
Old Jul 12, 2006 | 06:49 PM
83Z28406's Avatar
Car: 83 Z28
Engine: 400
Thats why I took it back apart was to check all the seals to see if any were torn or anything but they all seem fine but the book says to check the clearance between the upper retainer ring and the backing plate by pushing down gently then measuring .045'' - .070'' clearance I have this much without pushing down on the backing plate??
Old Jul 12, 2006 | 07:13 PM
87zjeff's Avatar
exactly ho much do you have? i personally think .075 is way too much.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
mfp189
Sep 27, 2015 09:25 AM
