What other cars/trucks can i get a 700r4 from
Old Jul 14, 2006 | 03:20 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Im goin 2 the J/Y this weekend and i was wondering What other cars/trucks can i get a 700r4 from that are compatible with everthing (computer)my engine is a lil 305 carb quadrajet
Old Jul 14, 2006 | 03:47 PM
ede's Avatar
ede
you going to be limited to something with a SBC and provision for a torque arm. look for other 3rd gen F bodys
Old Jul 14, 2006 | 03:54 PM
xgtharo86x's Avatar
Car: 86' Trans am
can it beout of a v6 3rd gen
Old Jul 14, 2006 | 07:03 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Nope, it has to be from a V8 car/truck (v6 models have a different bellhousing)... As long as you have an F-body extension housing for a 700R4, you can make any V8 700R4 work (except maybe corvette)... But, keep in mind that all of them have different valvebody/governer calibrations, so it would be best to find one from an F-body..
Old Aug 3, 2006 | 08:36 PM
xgtharo86x's Avatar
Car: 86' Trans am
wut do i have 2 do to put in a th400 or th350
Old Aug 3, 2006 | 08:52 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
th350 is direct if you go with a truck one 9" tail
th400 shorty you need a 200c shaft
700r4 can be from anything 2 wheel drive and 4.3L v6 or straight six or v-8 chevy only
astro vans, s-10s, caprices, etc.
but not corvette
and some caprices in the early 90s had a wierd length 700r4 too, but you probably wont run into one
the person who said it has ot be f body only because of the tailshaft housing is smoking on something funny, all you have to do is swap the housing for your f body one
duh.
Old Aug 4, 2006 | 01:21 PM
Shagwell's Avatar
Car: projects.......
T350 or T400 swap require an aftermarket non-tailshaft mounted tq arm, or a special mount to bolt the tq arm onto. - With the proper length T350, you can re-use your ds, all other will require a new or re-worked ds. You'll also have to modify or change you shifter. You'll be loosing the lower 1st gear and also OD, so if you need mpg, stick with the 700r.
- as stated, trucks, vans, 4.3 S10's have interchangeable trans, but will require your tailshaft housing. Also(as stated) most have differently calibrated vb's, so you may loose some performance....
Old Mar 22, 2007 | 09:50 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
Re: What other cars/trucks can i get a 700r4 from
So I could install a 700r4 from a chevy c1500 truck? How hard is it to swap out the tailshafts? Also, what is the truck version's gear ratio's compared to the camaro's?
Old Mar 25, 2007 | 05:42 PM
thirdgen88's Avatar
Car: 1995 Corvette
As long as it is a C1500 (or 2WD), then you don't have to swap the tailshaft.. You'd have to change over your extension housing (tailshaft housing) so you could mount your torque arm, but that is easy.. Pull the speedo out (one bolt), then 4 bolts mount the extension housing to the transmission case...
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
