2.77 to 3.27 is this all I need?
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Ok, I order to go from my 2.77 to 3.27's, I am going to need the pinion, ring gear, and carrier correct? Anything else that I'll need?
This is what I got so far:
Thanks!
Thanks!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 2.77 to 3.27 is this all I need?
are those caps from your rear or a different? they are all different and specific to each individual rear, as well a left and right. do not mix them up or you will be f-ed.
if the 3.27 requires a different carrier, then yes, all you need is the gears and the new carrier, unless you get a new set of gears, then you can get a gear set already set up for whatever carrier you already have. new bearing are also a good idea. you can use your old yoke, the splines are the same for all 7.5 10 bolts.
you also need the appropriate speedo correction gears.
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks! Everything in that picture is from a 3.27 rear. Looks like all I need is the carrier and ring gear from that rear end.
Car: 86 Trans Am
like i said, use your bearing caps, dont use the ones from the other rear.
Car: 1988 IROC-Z
Engine: 427 SBC
Car: 1984 Trans Am
If I'm not mistaken, ring and pinion gears are matched sets which are lapped together. You can not mix non matching part without something bad happening.
