Old T-5's
Old Jul 15, 2006 | 05:26 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Old T-5's
I was wondering how one can expect an old T-5 into the 100,120k mile range to hold up. How can you check(other than a test drive) the condition of a T-5?
Not to be an ***, I know that there are alot of poeple that have T-5's that have held up to a million miles, I'm just looking for some real world opinions on the level of abuse they can take over time.
Old Jul 15, 2006 | 09:23 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I had my T-5 in my 87 for 116k worth of road course and a little drag racing.........so I took it to a tranny shop befroe I put the LT-1 in it.....the guy took it all apart and found nothing worn, so he put it back together with new seals........I don't know if this is typical or not........but it still shifts great....
Old Jul 16, 2006 | 01:23 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
That's exactly what I was looking for thanks.
Old Jul 16, 2006 | 10:45 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The question is heavily loaded. It depends entirely on how the trans was treated. A properly treated trans can go 200,000 + miles without needing a rebuild as long as the fluid is changed regularly. A trans that is run hard may only last 50,000, or even less if the guy shifting it is a ham fist.
In general, if it doesn't make any noises and shifts smoothyl then it's probably fine. If it makes noise or shifts with grinding or rough engagement or pops out of gear it's rebuild time.
Old Jul 17, 2006 | 12:04 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
good to know. Wow, I wish all my quetions in life could be completely answered in a couple short sentences. Thanks.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
