driveshaft
Old Jul 16, 2006 | 02:06 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
driveshaft
ok i have the tranny back in the car, now im in a pickle, driveshaft wont go in all the way to clear the yoke, now what do i do
Old Jul 16, 2006 | 03:25 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
where do you have the rear of the car supported?
Old Jul 16, 2006 | 04:59 PM
Car: 87 trans am
it came out where i have it supported, rubber mounts on sway bar, if you look at the shiny part of the yoke that goes into the output shaft , half of it slides in and then it just stops, i took it back out and tried again and it just slides in and just stops, seems like it is hitting something
Old Jul 16, 2006 | 07:47 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Try rotating it a little when you pull it out, then put it back in.
Old Jul 16, 2006 | 09:11 PM
Car: 87 trans am
it was the new bushing i installed, i took the extension housing off and put the driveshaft in it and the new bushing was catching it.my old one most of been worn out pretty good, sanded the yoke down a little with emery cloth, had to turn and push it
in , its in now, thanks 87zjeff and BRobinson
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
