T-56 users, what fluid do you use??
Old Jul 17, 2006 | 03:24 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I was told by a tranny guy to use Royal Purple Syncromesh (sp) its suppost to be better for the syncro's. Any thoughts?
Old Jul 17, 2006 | 09:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That works but its more expensive. I use regular ATF. Do not use any kind of gear oil. That is not compatible with the synchros.
Old Jul 17, 2006 | 11:55 PM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
4th gen CMC car - Redline D4 ATF.
Old Jul 20, 2006 | 01:24 PM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Plain old Dexron III ATF in mine....
Old Jul 20, 2006 | 01:51 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
mobile 1 synthetic dextron III ATF
or
Honda ATF.
both of them work great, and the car shifts noticably nicer with them.
if you get the royal purple stuff, DONT get the manual trans stuff... its thick and ment to replace gear oil style manual trans oil.... its not ment for ATF type manual transmissions... they do make a ATF for that though.
Old Jul 20, 2006 | 02:03 PM
Randy92Z's Avatar
Engine: Miniram 383
Yea, I knew that, It even says on the syncromesh bottle thats its for ATF fluid trannys only. Thanks.
Old Jul 20, 2006 | 03:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
cool. thats the stuff then.
didnt mean to insult you or anything.. its just that there are atleast two kinds that i know of...
considering what a great improvement i got from the other two synthetic ATFs i used, im sure it will work great.
Old Jul 20, 2006 | 03:12 PM
Randy92Z's Avatar
Engine: Miniram 383
Oh no man no insult at all. Im still grateful to you for helping me with my T-56 install a few years ago! Thanks again
Old Jul 20, 2006 | 04:58 PM
ssean92's Avatar
Car: sold
i use the r/p and love it. shifts so much better then reg atf. well worth the money, but then again i only use syn. engine oil also
Old Jul 21, 2006 | 02:44 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
dextron 3 or compatiable
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
1MeanZ
Dec 18, 2015 05:39 AM
tonys91rs
Oct 10, 2015 03:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Numbah-1
Sep 12, 2015 08:57 PM
