700 R4 question!
Old Jul 28, 2006 | 11:17 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
700 R4 question!
Can you make a 92 7004R work in a non computer controlled carb set up? Or do I need all the wires and whatnot?
Old Jul 28, 2006 | 11:34 PM
jr. gearhead's Avatar
Car: 83 T-Top w/ 85 Z-28 and 91 RS parts
Engine: 377 (in progress)
Transmission: 700-R4 (unless i find a t-56)
Axle/Gears: from the Z
yes. do a search for the wiring you need to make the torque converter lockup work (basically a couple of switches and a plug for the tranny) and go for it. i will assume that it is a 700 and not a 4L60E, you will know by the absense of a round 14 pin plug on the pass side and the presence of the tv cable
Old Jul 29, 2006 | 06:16 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I havent recieved it yet, suppose to meet a dude on the 9th of Aug. I already knew I had to wire up a lockup for the TC but is that all I have to do though?
Old Jul 30, 2006 | 11:22 PM
that should be it.
Old Jul 31, 2006 | 08:39 PM
k9ulan's Avatar
anybody know which switches and wire? have recently aquired an 83 Camaro. Problem is that it doesnt shift right, It pulls good.. I beleive the transmission is an electric shift and the moror has been changed to a 305 carb with no computer, Is there anything I can hook up to the tranny to make it shift correctly, If not, what kind of transmission fits in this car with torque arm and all, length ect..Obviously im not too familliar with 3rd gens..any help would be appreciated..Thanks..Chuck
ps im not sure of the transmission type at all, sppedometer jumps around if that means anything
Old Aug 1, 2006 | 01:23 AM
not to be rude, but a search should help tremendously
Old Aug 1, 2006 | 04:24 AM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Your 83 is guaranteed not to be computer or electric controled shifting
If it's an overdrive is probably a 700R4
Make sure your TV cable is properly adjusted
Old Aug 1, 2006 | 05:57 AM
cammy's Avatar
Car: 80's somting Trans AM
Engine: 5.0L H.O.
Axle/Gears: not sure yet
adjustment is some times not enougfh a friend has a 79 trans am and the cable is split in a spot and had to be replaced
Vintageracer
Jan 10, 2020 05:33 PM
84 TA NV
Sep 6, 2015 08:02 PM
tonys91rs
Sep 2, 2015 07:07 PM
Mickeyruder
Sep 2, 2015 02:45 PM
