left rear wheel bearing,, making whining noise?
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
while checking out the rear end up in the air on my 91 r/s 3.1 it appears i need a new left rear wheel bearing .,could this be the anwser to my whining back there? and explain why when im rolling and barly touch the trhottle it whines and when i lift up on it it stops's for so long i thought it was the rear end going out but apperently its the wheel bearing., i could here the whining coming from behinde that tire,. and the more gas my girl gave it it got louder and started to shake a lil like vibrate.,.,.,,.also i notice when she applys the brake the right stops fine while the other keeps going also accompanied with the noise.,,.So with all this said what do all of you think??
well honestly dude i guess im axpecting to hear folks say well """"""replacin a rear wheel bearing is not tthat easy to do""""" also perhaps i shoulda said im only about 75% sure its a wheel bearing .,,.,.Oh and i wanted to know if any one has had a rear bearing go bad and what kinda noise it made??
Originally Posted by ede
ok since you don't know what it is why don't you start inspecting parts, like bearings
sounds like a good idea !!! sooo how do i check the bearings other then shaking the wheel,.., im limited on cash and need to get to orange county
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
