305 Manual flywheel bolt to a 350
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
yes....it should they both use the same crank so i would asume it would work
It depends on the year of the 350 and the 305.
If the 305 is original to the car, it has the 1-piece rear main seal.
If the 350 is 86-up, with the 1-piece rear main seal, then yes it will work.
If the 350 is 85-back, with the 2-piece rear main seal, then no it will not.
If you have the early style 350, you need th eflywheel for 83-85 Camaro/Firebird V8. You will find there are 2 types; one weighs 22 lbs or thereabouts, and the other weighs 16 lbs or so. The former is the grocery-cart version, from the LG4; the latter is from L69 and LB9 performance applications. You'll probably want the light one.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
oh well he will find out if they are not both the same year group when he tries to put the flywheel on and it wont go lol
good luck
good luck
