what rear would fit?
Old Aug 11, 2006 | 11:00 AM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
what other cars rear ends will fit my camaro 86 350 v8 with t5 manual tranny.. what other cars rears will be a straight bolt in. i want disc brakes any help would be good thanks
Douglas
Old Aug 11, 2006 | 11:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Only another thirdgen rear is a bolt in. A fourthgen rear bolts in too, but is an inch or two wider.
Old Aug 11, 2006 | 11:06 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
Look for a rear from a GTA, I found one in the junkyard, it was a 10 bolt disc brake rear with 3.73 gears and positraction. The 9 bolt rears are a little stronger due to the slightly bigger ring gear, but the best ratio offered was 3.70 which is rare, and you cannot get a lower ring and pinion than 3.70. Where as the 10 bolt had various factory gearing and various aftermarket choices.
customblackbird
Aug 15, 2021 10:16 PM
I'llrocya
Feb 2, 2016 11:43 PM
hectre13
Aug 26, 2015 08:17 AM
z28addict8490
Aug 7, 2015 08:48 PM
