Funny Sound In Tranny
Old Aug 12, 2006 | 12:38 AM
Pradamatic's Avatar
90 RS 305 TBI...makes an almost grinding noise when I shift into anygear. Auto trans, doesn't do it when it is shifting while driving but does it when I first put the car into gear. I think it gets worse when it is hot, or at normal oper. temp. It stalls for a second then "clunks" into gear. Any ideas?
Old Aug 12, 2006 | 12:50 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Id first chek my u joints and driveshaft before I presumed it was the tranny.
Old Aug 12, 2006 | 12:57 AM
Pradamatic's Avatar
I am not too car smart...I am learning slowly but surely, could the u-joints and the driveshaft be bad or need fixed or what...how do I tell if the u joints are bad and where are they located, same goes for drive shaft, well I know where it is but how can I tell if it is bad
Old Aug 12, 2006 | 01:28 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
More than often on these cars, a loud thunk while shifting out of park means that the U joint is gettin a lil worn out. The u joint is located near the rear of the driveshaft right before the axle. If the driveshaft needs to be replaced, it usually makes a loud obnoxious buzzing vibration while up to speed on the highway. At least this is what I've learned from my car mishaps. If there is no visual confirmation that the u joint needs repair... You might wanna have a mechanic inspect it. Especially if You hear grinding noises!
db057
Jan 10, 2020 08:55 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
