Trying to remove posi from 4th gen axle, what am I missing?
Old Aug 13, 2006 | 05:57 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Ok, I'm trying to pull out the posi and gears from a 2000 4th gen rear. 3.42 to be exact if it makes a difference. Anyway I removed the keeper brackets and the little bolt in the posi unit and pulled the middle peice that keeps the axles from moving inward and I removed the U-rings that hold the axles in and then removed the axles themselves. Now this is where I need help. Am I missing something that is different than the 3rd gen posi rear?
I cannot even loosen the posi. In my rear, I do all of the above, and the posi almost slips out. Or is that a sign why my 3rd gen rear is bad, it shouldn't be removed that easy.
Please help.
Old Aug 13, 2006 | 06:49 PM
4 bolts that hold the bearing caps in?
Old Aug 13, 2006 | 07:13 PM
Car: 1994 Trans Am
Those things were the first to get unbolted and put into a cup.
It was tougher to get out, but I just used brute strength, and Hercules styled, I lifted the rear and banged the other side of the rear against the conrete and out she came.
Now, I got to get the pinion gear out. How big is the bolt holding it in? Looks almost like 1.75 inches.
Old Aug 14, 2006 | 09:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
something huge alright... I think a 1 1/4" socket was needed to remove the nut off the pinion. You'll need something to hold the yoke still too, I made up a gizmo out of angle iron with 2 holes in it to bolt to the yoke, then stood on that, and used a beefy snipe to loosen the nut.... Turns out 20ft/lbs was about all it took to **remove** it the first time (ultra loose!), but tightening it back in later is where you'll use those tools.
Old Aug 14, 2006 | 09:49 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The side bearings have considerable preload. Normally you use a case spreader to get it in and out. A prybar will work to get it out.
I remove pinion nuts with an inpact. You can put a u-joint strap on the yoke then use a prybar to keep it from turning while you loosen the nut. A special holding wrench bolts to the yoke and has a hole in the center for the socket. It's difficult but not impossible to tighten the pinion nut and crush the crush sleeve without one.
Old Aug 14, 2006 | 01:48 PM
Shagwell's Avatar
Car: projects.......
I got your special yoke holding tool...I call it a 36" pipe-wrench.
Old Aug 14, 2006 | 01:56 PM
I use a 4' piece of ¼" x 1½" bar stock, with 2 holes near one edge; which I bolt to one of the U-joint cups with 2 of the U-joint bolts.
The nut is 1¼", like alot of GM rears in general. I use a BF breaker bar with a socket on that.
hectre13
Dec 11, 2023 08:14 AM
Casey Meyers
Mar 2, 2016 10:46 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
