how to tell what 10 bolt i have?
Car: 2003 chevy silverado ss
Engine: 6L with twinturbos
Transmission: built 4l65e
Axle/Gears: 4.10
if i post the part number on the rear end can someone tell me the spline i have and year? here is the deal i bought this car a few years ago and when i pull the rpo codes from the vin it says this car came from the factory with a 9 bolt borg warner and a regular drive shaft. this car has a aluminum drive shaft and a 10 bolt rear end. when i first got it i put 3.73 gears in it but i can not for the life of me remember what size and splines it has in it. im looking at putting either a spool or new posi unit in it. if someone can help that would be great thanks
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
As Sofakingdom would tell you: nothing on the outside will tell you with 100% certainty what's on the inside. You know it's not the original housing so who's to say someone hasn't swapped the inards? You'll have to open it.
Axle/Gears: 4.10
yeah i did change the gears about 3 years ago when i put the richmonds in it. i wish i could remember what size it was.. i think its a 7 5/8 10 bolts but i cant be sure ill just have to wait till i can open her up..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's in a thirdgen, it's a 7.5/7.625" 10 bolt. That doesn't tell you anything about the spline count, though.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
