What Are These Noises??
Old Aug 31, 2006 | 11:47 AM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
I finished putting in a 3.42 10 bolt posi rear I got from a friend. Its pretty much a junkyard 100K mile rear end, but the posi is good. I took all the drum brake stuff off my original 2.73 rear and put it on this one.
Some of the noises it makes are:
A washy grinding sound, kinda like draging a hammer across a concrete floor, except lower pitched. It makes that sound constantly, and slows down/speeds up with vehicle speed.
During hard turns the rear end howls. Its louder during right turns, and quieter when turning left. It only does it when going 20+mph.
I added a bottle of posi additive. I dont think it made any difference.
Old Aug 31, 2006 | 12:16 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Just out of curiosity:
Did that rear end come out of a stick shift car?
The reason I ask is that I've had 3 5 speed 3rd gens. An 84 T/A, an 87 Formula, and the current 88 "Project X"; they all have given me the same problem.
The noise was that my pinion had loosened up and was slipping deeper into the rearend causing the horrible noises you describe. My Formula was so bad that when I pulled the back cover I could see pinion tooth scrape marks all around the center of the differential carrier!!
Anyway, you better pull the cover and take a look. I pulled the driveshaft out, took the nut off, changed the pinion seal which was leaking, torqued the nut back down and then tacked the nut to the pinion with a mig welder!
No problems after that! Of course, welding is not the preferred method but I wasn't planning on keeping it long. I never thought it would last forever...
... but it did!
Good luck finding your problem!
Old Aug 31, 2006 | 01:35 PM
Shake Zula's Avatar
Wouldnt the noise during turns most likely be the posi or wheel bearings?
Old Aug 31, 2006 | 02:03 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Does it look like your front pinion seal may have been leaking?
I think you better take off your cover and have a look inside. It will only cost you one rear axle cover gasket which is pretty cheap. Like a couple of bucks cheap.
You can even re-use the fluid!
Then you'll know for sure...
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
