i think i finally killed the 10 bolt
Old Sep 1, 2006 | 10:35 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
When i got the car, the gears always howled like a bitch. Well now...only at 58-60 mph i hear scraping..its wierd. The only way to describe it is if you jack your car up and spin the tire and you hear the pads touching the rotor and that slight scraping noise...it's like that, just super loud. Its coming from the driver's side. It seems to not be there at lower speeds though i think i may have heard it at like 40. I also hear what sounds like whirling when im rolling and apply the gas at like 20. Im thinking it has something to do with my axel...any comments? The scraping also gets much much louder when i apply the gas which makes me pretty dead set on it being the rear. I know the howling stops when im off the gas and when i reapply it its loud as all hell. I had a friend ride with me as well and he said it was deff coming from the drivers side.
Old Sep 1, 2006 | 01:42 PM
Shagwell's Avatar
Car: projects.......
if she's being chewing since day one, something has probably finally gone. Bearing, gear, etc.
Old Sep 1, 2006 | 05:24 PM
Car: 1991 Z28
Engine: SBC
unless it was the wheel bearings always making those howling noises...and now i finally killed one. The posi unit is a new zexel torsen, but thee previous owner said it always howled since it was put in...hmm
Old Sep 4, 2006 | 09:44 AM
Pat Hall's Avatar
It's usually an issue with one of the pinion bearings if it only makes noise with a load applied or when coasting. If it is your pinion bearings, you'll be spitting out ring and pinion teeth pretty soon.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
Ducati900ss
Sep 2, 2015 09:05 AM
InfinityShade
Aug 22, 2015 08:00 PM
