shift pattern
Old Sep 3, 2006 | 09:19 PM
insanesativa's Avatar
Car: 1992 S-10 Blazer and 1985 BERLINETA
Engine: 1959 283 sbc
Transmission: 350 turbo
Axle/Gears: moser rear end
shift pattern
anyone know how to change 1985 camaro shift pattern from PRNODD21 to 12DODNRP
Old Sep 3, 2006 | 09:52 PM
j dezzy's Avatar
Car: 87 TA
not exactly sure...with a few home fabed pieces it shouldn't be too hard to reverse it...why would you want to...?
Old Sep 3, 2006 | 10:02 PM
have to much money wrapped up in this 350 turbo
Old Sep 4, 2006 | 10:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ok....
If its a TH350 why would you want to put OD into the pattern?!?...
I imagine it could be something as simple as mounting the cable higher up in the shifter, past the pivot point and as high up as possible.
Old Sep 4, 2006 | 11:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Mount the shifter backwards.
Again though, why?
Old Sep 4, 2006 | 11:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's a reverse shifter, not a reverse pattern. Do do what you you want, install the shifter backwards with the cable coming out the back.
Normal shift pattern is PRN321
Reverse pattern is PRN123
To do that, you need a reverse pattern valve body.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
