thump noise? auto trans
Old Sep 8, 2006 | 06:57 PM
QuicksilverFX's Avatar
Car: 89 Pontiac Firebird
Engine: 305 TBI
Transmission: A4
i have a 89 firebird with a 305 and an auto and when i get on it theres a thump noise and i can feel it, is it normal or should i have it looked at? could it be somthing is modified and its just shifting? or could somthing be loose?
Old Sep 8, 2006 | 07:07 PM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
most likely just a busted trans mount. I had that problem after i took my car to the track. Anything could bust the trans mount though...not to expensive and easy as hell to replace, takes like 5-10 min.
Energy Suspension Transmission Mounts: ENS-3-1108R - summitracing.com
Old Sep 8, 2006 | 11:17 PM
Engine: 305 TBI
Transmission: A4
thanks
Old Sep 8, 2006 | 11:51 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Ya you can bet on it being the tranny mount.
Old Sep 8, 2006 | 11:54 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Yep!
Old Sep 9, 2006 | 01:04 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
ok just to clarify.. a contant thumping that only people in the car can seem to hear would be the tran mount (under accel). just making sure.. if so I am buying 2 of the stupid things. just so i have a backup.... thing gets annoying....
Old Sep 9, 2006 | 01:41 AM
86birdHT's Avatar
once you buy an aftermarket trans mount and still have semi stock torque you dont need to buy 2.
Putting that trans mount it somehow helped me hook up a little, unless thats my imagination playing games with me.
Old Sep 9, 2006 | 03:57 AM
thats not so much a concern as I have stripped out two cross member bolts in the past ( the ones holding the crossmember to the body) so something seems to be a little more than normal i suppose.. I have also replaced the one on another camro I have and it broke within a month.. but that was a poly.... and i hear that that can happen.
Old Sep 9, 2006 | 08:33 AM
Stevo's Avatar
No No what you guys need to do is just go ahead and buy a polyurethane one now and youll never have to touch it again(unless your dropping the tranny of course)
I know 2 people who have replaced them with factory rubber pieces and they have both broke them twice. Spend the $25 and get a mount that you will not have to worry about. Just my opinion
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
