TRANS BREAK OR STALL CONVERTOR...IDK WUT THE DIFFERENCE IS REALLY
Old Sep 8, 2006 | 10:30 PM
jd5944's Avatar
Car: 85 Camaro Z/28
Transmission: built 700r, B&M shift kit
I HAVE A 700R AND I NEED SOMETHING TO MAKE IT LAUNCH BETTER....SHOULD I GET A TRANS BRAKE OR A STALL...AND HOW SHOULD I LAUNCH UNTIL I GET ONE...
Old Sep 8, 2006 | 11:19 PM
EvilCartman's Avatar
Car: '82 Z28
I'M GUESSING YOU NEED A 5150 STALL CONVERTER. IT'S A GUESS BECAUSE YOU DIDN'T PROVIDE ANY INFORMATION ON THE ENGINE.
Old Sep 8, 2006 | 11:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you were racing seriously, you'd want both. A trans brake locks up the transmission to let you bring the engine up to the stall speed of the converter without moving the car. When you let the trans brake off, the car launches. If you were racing that seriously though, you probably wouldn't want to have a 700R4 anyway.
Old Sep 9, 2006 | 11:41 AM
jd5944's Avatar
Car: 85 Camaro Z/28
i have a 350 with 280 horses and 360 torque
Old Sep 9, 2006 | 11:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
To choose the stall speed for the converter, you need to know where the curves peak, not just the peak numbers.
Old Sep 9, 2006 | 08:25 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
You want a stall converter. Call Andre at EDGE Racing Converters He's arguably the BEST converter guy on the planet and will set you up with the perfect converter for your car.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
redmaroz
Aug 16, 2015 11:40 PM
