10 bolt question
Old Sep 15, 2006 | 10:11 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
10 bolt question
I understand that 88-up 10 bolts came with 28 spline axles. Is this the only change for 88? Can I take a pre-88 rear and install 28 spline axles with a 4th gen posi unit and bolt it up to my 91 RS?
And also: How practical is it to swap disks to a drum rear?
Old Sep 16, 2006 | 05:32 AM
ede's Avatar
ede
89 was the change year and most were still 26. yes you can swap a 28 spline posi in to your rear and add axles that match with no problems.
Old Sep 16, 2006 | 11:23 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Did the size/quality of the disk brakes change at all from 82-92? Also, what other cars came with rear end with all the same provisions and same size?
Old Sep 16, 2006 | 03:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Disc brakes changed from the problematic iron Delco Moraine calipers with the aluminum PBRs in 1989.
No other cars came with the same provisions and size.
Old Sep 16, 2006 | 05:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
So is it a worthwhile upgrade to buy factory 1991 Z28 front and rear rotors, calipers, and pads, and put them on a pre-'88 car? Everything bolts up, e-brake mechanism, mounting holes, etc?
Old Sep 16, 2006 | 07:22 PM
toms84ss's Avatar
I dont think the fronts are any bigger unless you find the 1LE package.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
