1-2 shift bad, the rest are good
Old Sep 10, 2006 | 05:54 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
the 1-2 shift in my tranny sucks, it is slow and has a bit of flare(rpms go up between shifts), but the 2-3 and 3-4 shifts are normal. i believe i read that this can be cured with a shift kit because a spring is broken or something.
is this true?
what else could cause this?
and can you install a transgo kit without removing the tranny?
Thanks!
Edit: this is a 700r4, and the fluid smells good and there is no sludge or crap in the pan.
Old Sep 13, 2006 | 09:44 PM
327???'s Avatar
it was a broken 1-2 accumulator spring, picked up a new one from a local trans shop along with a 'vette servo. put the new spring in now it shifts great at partial throttle but still has a slight slipping feeling at wot though. the 2-3 shift is great at all throttle openings. the 'vette servo has yet to go in becaus i'm having a hell of a time getting the lock ring off of the cover
Old Sep 14, 2006 | 11:13 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
yes the servo snap ring can be very stubborn after so many miles, might as well pick up a new one, just use a screwdriver and a hammer, pull the cover out a little bit then and then cut the o ring seal, usually green, pull the rest of the way out. may have to hit the cover with a rubber hammer to try and loosen it up a bit first, then try and get the snap ring out.
yes a shift kit can be installed with the trans still in the car, but if it is slipping, a shift kit wont correct it.
Old Sep 16, 2006 | 08:16 PM
327???'s Avatar
the slipping feeling was because of the broken spring.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
