Ok need someone with Rear end removal experiance
Old Sep 13, 2006 | 09:41 PM
kjvail1204's Avatar
I've searched and found bits and peices, maybe im listing it wrong but heres my delema.
I got a great deal the entire rear end 3.73 gears and all for $150.00 if i take them out. I would like to know how hard this is and what tools will make it easier.
Ill have about 4 sets of hands to make this go smoothly. If anyone has pictures of can get me pictures of jsut what i need to remove that would be a great big help. Im more of a pictures instead of words guy and if this is detailed enough maybe we can get sticky think this could be a great help.
Old Sep 13, 2006 | 09:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if its a piece for piece removal its quite straight forward. remove the driveshaft, disconnect the flexable brake lines, remove the panhard bar, remove the springs remove the lower control arms pull it out of the trans mount. think thats it. obvioulsy you need to jack the rear of the car up as high as you can and put jackstangs on the "frame rails" just in from the lower control arm mounts. put a floor jack under the rear to support it while you are working.
Old Sep 14, 2006 | 09:32 AM
kjvail1204's Avatar
The other car is on top of a another car, its in a junk yard so think i can get this done in under 3 hours im on a bit of a time crunch.
Old Sep 14, 2006 | 10:23 AM
ede's Avatar
ede
you ought to be able to get it done in way under 3 hours, more like 1
Old Sep 14, 2006 | 10:52 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Rear end removal and installation, pics and instructions
Does this help?
Old Sep 14, 2006 | 11:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's that much of a time crunch, you could have it out in under 5 minutes on a junkyard car. Sawzall through the LCAs and shocks, bolt cutters on the brake cables and hoses, unbolt the driveshaft and it's done.
Old Sep 14, 2006 | 02:46 PM
ede's Avatar
ede
yeah i was thinking hot wrench would make short work of it
Old Sep 14, 2006 | 06:13 PM
kjvail1204's Avatar
I was thinking sawsall but i dont think i can get power out there anyhow. Thanks so much guys, and the one link with the step by step and pictures that is awesome, and you got alot of cool mods on there, is there anyway you can send me those pictures on like a CD or something. Front end and rear end i think a good slide show would be awesome.
I dont know if any of you have power point but we could make step by step instrcutinos on removing all of the things we ThirdGen lovers do. I think im going to take my camera and laptop to the Junk yard and get step by step pictures of everything we do. Ill get started on the Power Point and let you wall know when its done
If anyone else has any hints or tricks keep it coming fella's this is a BIG HELP
Old Sep 14, 2006 | 06:19 PM
krisb410's Avatar
Front end rebuild
Here's the front end rebuild.
BTW: That's not my car, I did a search and found the links here on TGO. So I'm just reposting the links. But they are very helpful
Old Sep 16, 2006 | 09:21 PM
kjvail1204's Avatar
Hey guys got the rear end out and all that fun that came with it ill post some pictures here soon. youwouldnt believe where i found the car.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
