DONT READ THIS!!!
Old Sep 20, 2006 | 08:50 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
DONT READ THIS!!!
now that i have your attention....
does anyone know where i can get gears for a 9 bolt? i gotta ditch my 2.77s. id like to go 3.27 or 3.45. ideas???
oh and sorry for the cheap trick (hey you clicked it didnt you? )
Old Sep 20, 2006 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
sneaky bastard lol
Old Sep 20, 2006 | 08:55 PM
EvilCartman's Avatar
Car: '82 Z28
Ok, I wont read this.
Old Sep 21, 2006 | 09:27 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I had a 2.77 9-bolt once, now it is sitting empty in my garage. The problem is you have a 2-series carrier and I believe the best you can get into it would be 3.08. You'd need a 3-series carrier for gears numerically higher than 3.08. I said eff it and went with a 10-bolt.
You can try Richmond Gear, Jeg's, Summit, or do a google search for 9-bolt gears and click away.
There's a post around here somewhere entitled "Everything I Know About 9-bolts" that may help you in your decision. I couldn't find it only due to lack of time.
Buena Suerte....
Eric
Old Sep 21, 2006 | 12:49 PM
Shagwell's Avatar
Car: projects.......
yes, you have a 2-series carrier. You'll have to locate a complete carrier as well as a gear, meaning more time and money than it's probably worth.
There are few sources to get any of the parts from. Do a search, there are several threads on here.
Old Sep 21, 2006 | 02:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Could he not just replace the posi? Doing that would also get him the 3 series carrier he needs for the shorter gears, no?
Old Sep 21, 2006 | 08:19 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
If it was that easy I'm going to shoot my mechanic. He & I went thru hell AND high water and ended up having to go with the 10-bolt. I can't remember the specifc reason, but the 3-series carrier just wasn't available or the housing was too small or someshyte. I wanna know the answer to that too........
Old Sep 21, 2006 | 08:21 PM
Air_Adam's Avatar
Unless I misunderstood, the posi/diff IS the carrier....?
Old Sep 22, 2006 | 01:41 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
I think Randy's ring and pinion may carry 9 bolt stuff. Also Diffsolutions.com if he is still around.
Old Sep 22, 2006 | 01:09 PM
Shagwell's Avatar
yep, and reider can usually get the 3.70 gear and sometimes the instal kit.
yes, and yes, now try finding a complete carrier for a 9-bolt. Parts for a 9-bolt are practically non-existent.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
