Fluid Leak
Old Sep 24, 2006 | 02:28 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
Fluid Leak
I have been messing with this leak problem for months now. i dont have any leaks anywhere else besides the output shaft. before i did the rebuild and shift kit, didnt have a problem. i now have a deeper pan(b&m's considered stock size pan) which side by side, the b&m one is deeper. i have it a little over full, and lately i have been taking fluid out, still leaks.it only leaks going down the road, wont leak in the driveway until just recently. which is making a mess of my underbody, cleaned it up the other day. i put in a new seal thinking the old one may be defective, still leaks, i silicone the endes where the seal and the aluminum is , different style seal where the whole thing goes into the end, no lip covering over the end ledge of the housing. still leaks a little.could it be that it is just to full
Old Sep 25, 2006 | 05:02 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
doubt it. might check the housing for any kind of defect(guoge in the sealing surface, crack in the housing.
Old Sep 27, 2006 | 05:02 PM
Car: 87 trans am
no cracks or anything, doesnt leak at all where the extension housing bolts up to the tranny.
Old Sep 27, 2006 | 06:23 PM
Car: 87 trans am
my buddys teacher at school told me to check the vent tube, i lower the tranny down to see it something was in front of it, nothing. l looked up there and saw a little fluid stream start to fall down the side ay the end of the tranny, not the ex. housing part end. looks like it might be coming out of the tube, too full then
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
HikoriYami
Sep 21, 2015 07:11 PM
Stryker412
Sep 20, 2015 06:59 PM
