Difference between LT1 rear end and a LS1 rear end
Old Sep 24, 2006 | 08:12 PM
mike17's Avatar
Hey, I just purchased a rearend off of ebay. In the ad it said it came out of a 2001 SS camaro. Now when i got it home, I talked to a friend of mine and he said that it might be a lt1 rearend. beacuse of the wiring thats on it. Now I've search the internet for awhile now and im getting mixed answers.
The rear end I have has a plug going into the diff. My buddy said that its an lt1 rearend because of the plug. and the ls1 had 2 plugs that went to either side of the rearend.
What is a sure way I can verify what this rearend is.
Old Sep 24, 2006 | 08:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The calipers on the LT1 should look pretty much like the ones in the following link:
https://www.thirdgen.org/forums/atta...s-89-drcar.jpg
Check this link for what the calipers on an LS1 look like (about halfway down):
https://www.thirdgen.org/ls1reardisc
A search on this site is always a good thing.
JamesC
Old Sep 25, 2006 | 07:24 AM
mike17's Avatar
The rear end diddnt come with brakes. its just the rearend by itself.
Old Sep 25, 2006 | 01:34 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
LT1 and LS1 had either one plug in the pumpkin or one plug on each axle, depended on if the car had Traction control or not. Trac Cars had plugs on each axle in the backing plate. non-Trac cars had one plug in the top of the rear end.
It doesn't really matter what rear you have as they are pretty much the same, only main difference is that the axles on LS1 rears have smaller hubs on teh axle ends (the hub portion that the rotor slips over).
A 98+ wheel won't go on an LT1 rear axle without grinding the axle or the wheel.
Old Sep 25, 2006 | 07:42 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
LTx axles have an Auburn cone style posi. LSx axles use Torsen gear driven posis. Pop the cover and see which style you've got.
Old Sep 26, 2006 | 05:49 AM
ucantctchme1's Avatar
If its out of an SS car 2001 it will have an auburn.
Old Sep 26, 2006 | 09:54 AM
Zepher's Avatar
Nope, the auburn was an option still on the SS's. My rear I have now is from an 01 SS and it's got the Torsen.
Old Sep 27, 2011 | 11:29 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Re: Difference between LT1 rear end and a LS1 rear end
so lenth any factor axle spline count
Old May 18, 2020 | 01:52 PM
Tidan's Avatar
What axle is this?
1984HO
Mar 19, 2021 11:59 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
