4L80E Pump\Torque Help!
Old Sep 25, 2006 | 11:24 AM
1raider's Avatar
I have a 95 4L80e and am having issues with it. When i put it into gear seems fine for about 15-20 sec then it wants to stall. Neutral and park are fine. If i go to drive it it just dies, as soon as any throttle is applied. would this be the Torque converter hooking up to early or would it be the pump applying to much pressure. Please help
Old Sep 27, 2006 | 10:02 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
it might be the lockup circuit (brake switch not working right) or solenoid sticking on, locking up the torque convertor.
Old Sep 29, 2006 | 04:08 PM
JDud's Avatar
I don't know what type of engine/pcm your are running but I know that some pcm's require a vss input from the tranny to calculate vehicle speed/engine load and that goes into your fuel injection calculations...
Does your 4L80E provide the same type of signal to the pcm that your old tranny did?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
