th350 + 3.42rear ?
Old Oct 2, 2006 | 08:47 PM
kjvail1204's Avatar
th350 + 3.42rear ?
Just wondering if this is a bad setup. The rear is already in and i can get a th-350 for $150. THe guy with the tranny said id hear it whine, but i heard from a guy that was running 4.10 and it was fine.
Also can i change the the 700r4 cross member or do i need to get a th350 bracket.
If someone has one cheap and is willing to ship let me know. thanks guys and let me know asap.
Old Oct 3, 2006 | 03:39 AM
ede's Avatar
ede
ratio has nothng to do with what you hear, or don't hear. as for it being a good combination a little depends on the engine, but you never mentioned having an engine. look at the b&m kit. i use to know the pn, 30029 might be it.
Old Oct 13, 2006 | 12:23 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
I was using a th700 with 4.10 with 27"tires it was fine like 2300rpm at 65MPH.
Then i swap to a th350 still hade th 4.10 it was ugly 3500 at 60mph so i switch to a 3.42 its now pretty fine for me 3000 at 67 mph.I like the th350 close ratio is very good for the 1/4 mile... in my advice bether than the th700 but got no overdrive its a good for a bad...
Old Oct 16, 2006 | 02:44 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
th350
with smok, i just put a th350 in one of my thirdgens with a 4.10 gear, it rocks the eighth mile hard, but 3500 rpms down the highway gets old fast. not to mention it kills the gas mileage. but it does make it a blast to drive in town.
Old Oct 16, 2006 | 02:56 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
it really depends on how much you drive on the highway
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
