??? about flywheel ? flexplate bolts
Old Oct 3, 2006 | 07:59 PM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
Would the bolts from a flexplate be the same as those used for a flywheel? In length, I mean. I am doing a auto to man trans swap in my k5 blazer, and with the flywheel being thicker than the original flexplate, I might need longer bolts. The difference in thickness is only maybe 1/4", but this is somththing that has to be right.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the bolts are different.
Old Oct 3, 2006 | 08:03 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
That is what I was thinking. Thanks, guess I will have to get some.
Old Oct 3, 2006 | 08:09 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
Gotta love the big box parts house. Their website only lists flywheel bolts, but also calls a flexplate a flywheel and the bolts are listed for auto or manual. I will check a little deeper and figure out the length difference.
Old Oct 3, 2006 | 08:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Manuals from used P/N 839756 or 14088645, no dimensions listed in the catalog. Automatics used 14088764, 7/16-20x.7
Old Oct 3, 2006 | 08:33 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
Thanks, I will see what I can come up with later this week.
Old Oct 3, 2006 | 08:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The ARP catalog shows 100-2801 for the flywheel, 7/16-20x1, and 100-2901 for the flexplate, 7/16-20x0.68. Either one is about $8 at Summit.
Old Oct 3, 2006 | 08:42 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
I might go that route, good excuse to order some other stuff from summit anyway. Thanks
Old Oct 4, 2006 | 06:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
my local parts place (like autozone), had them on the shelf. $6 I think. Mr gasket brand.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 7, 2015 08:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
