WTF! auto to manual t5
Old Oct 10, 2006 | 09:29 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
im doing the auto to manaul t5 conversion. i have a 85 camaro, i have tryed a 85 and 87 flywheel nether of them works. which flywheel do i need? on the auto flexplate the main center hole is about 2in. on both the new wrong flywheels they are about 2.5in. need help!
Old Oct 10, 2006 | 09:46 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You need a flywheel for a 2 peice rear main seal. The one for the 85 should have worked. Maybe someone put a later model engine in the 85.
Old Oct 10, 2006 | 10:15 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont know what size you need, but if both the 85 and 87 flywheels are 2.5" then they're not 85 and 87, they are the same.
Old Oct 11, 2006 | 06:02 AM
jayk2k3's Avatar
Car: 85 camaro z28
i have a replacement engine in it. so i dont know what flywheel to get.
Old Oct 11, 2006 | 09:28 AM
Is the crank flange absolutely round, or is it sort of funky shaped and irregular?
If it's perfectly round, you need a 86-up flywheel.
If it's the irregular shape, you need a 83-85 flywheel.
If you have 2 flywheels and one is "supposed to" be a 87 and the other is "supposed to" be for a 85, and they're the same, then whoever was doing the "supposing", wasn't doing it hard enough. The correct flywheels for those 2 applications are different.
Sounds to me like you have 2 83-85 ones, not a 85 and a 87.
You need one of the 2 flywheels that's available for 86-up V8/T-5 Camaro/Firebird. You will find that there are 2; one that was used on the high-perf motors (L69 and LB9), and one that was used on the grocery-cart motors (LG4 and L03). The difference is the weight: about 16 lbs vs about 22 lbs. You'll probably do better with the lighter one.
Don't forget to put a pilot bushing or bearing inthe crank. Your transmission WILL be destroyed if you don't, and quickly.
Old Oct 11, 2006 | 05:08 PM
jayk2k3's Avatar
Car: 85 camaro z28
thank you so much bud. you save me a big headark.
RyanJB
May 7, 2016 06:23 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
88rscamar0
Sep 23, 2015 09:08 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
