Shifter not catchin all gears.
Old Oct 11, 2006 | 09:32 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
I installed a new shifter tonight (the pro5.0) i love it except for 2 little things... it doesnt go into 5th or reverse... im not sure what to do... any suggestions? thanks
Braden.
Old Oct 26, 2007 | 04:53 PM
91z28tpi355's Avatar
Re: Shifter not catchin all gears.
Have you figured this out yet? I am having the same problem, except for mine worked fine before, but I just installed a centerforce clutch, and now after I reinstalled the shifter, it will not go into 5th or reverse.
Old Oct 29, 2007 | 12:25 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
there are ways to adjust the position of the static shifter from side to side. If it's too far left, there will be too much play in that direction and you wont be able to move the shifter enough right to get to 5th and reverse. Play around with it till you get it
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
