How would YOU build a 10 Bolt?
Old Oct 20, 2018 | 11:24 PM
  #51
Hal54's Avatar
Car: 1989 Iroc
Re: How would YOU build a 10 Bolt?
I own a 89 iroc since new. Recently noticed a leak in the rear diff. Cover as well as dirty oil. So not sure if the is any benefit to swapping in a 4th. gen. as I have rear disk, posi, 3.73 gears. However my thought is with 339000 on the car preventative/ upgrade may be in order. Slight modifications,rv cam, bbs throttle body,headers,3” exhaust. Your thoughts
Old Oct 20, 2018 | 11:39 PM
  #52
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
other than leaks does yours work OK? I added a Tom's differentials alum cover and a torsen unit out of 4th gen to mine, not a whole lot can be done to the 7.5" rear
Old Oct 21, 2018 | 01:42 PM
  #53
Hal54's Avatar
Car: 1989 Iroc
Yes it seems to be fine,however with 339000 km. I feel there has to be something worn out. This winter I plan on raising the car to pull the tranny( main seal leak) and I have to replace the fuel pump. So I have no problem dropping the axle . If that is not necessary then gear inspection and possible change.
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
bdads
Aug 24, 2015 06:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
