couple questions??
Old Oct 18, 2006 | 04:43 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 5 speed
couple questions??
k first what is the ring bolts supose to be torqued down to?? also when puting a higher gear ratio in does it mess with your spedo? if so whats the cure for this? thanks
Old Oct 18, 2006 | 10:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ring bolts are something like 60ft/lbs with red loctite. Check in your haynes or something to be sure, maybe it was 70ft/lbs.
Use new bolts too, they're cheap.
Yes, your speedo will be off, you'll need a new speedo gear. Talk to the guys at your local stealership, the gear is about $11.
Old Oct 19, 2006 | 06:06 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
awsome thanks alot
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
