pilot bushing dimension?
Old Oct 22, 2006 | 12:33 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Does anyone know the spec for how far the pilot bushing should extend from the back of the crank flange?
Thanks-
Old Oct 22, 2006 | 04:54 AM
ede's Avatar
ede
it shouldn't extend past the crank flange at all. i put them in untill they bottom out.
Old Oct 22, 2006 | 12:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
make sure the countersunk edge is facing outwards, and not inwards. Makes installing the trans a heck of a lot easier.
I think it'll be in about .020" or so from the back face of the crank.
Old Oct 23, 2006 | 10:25 AM
Flip 2's Avatar
Engine: C5 LS1
McLeod piece
Thanks guys.
I got a McLeod extended bushing, to go with my T-56. It is different. It will need about .600" taken off to fit right. Right now it extends out from the crank. A bit of measuring showed me how far wrong it is.
The crank is aftermarket, so some of the mis-match may be at their door.
Think I will countersink the bushing, also, after it is shortened. I can hear the cussin', already, if I don't.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
camaro1185
Oct 26, 2015 06:51 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
