Stock limited slip
Old Oct 24, 2006 | 04:13 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Stock limited slip
I've got a 91 rs with a the stock limited slip differential and 2.73 gears. I was just wondering if this differential is as good as an aftermarket and would I have any traction after adding 3.73's?
Old Oct 24, 2006 | 04:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
RS, what motor?
It's not as good as the aftermarket ones you can get, but it's free right Aftermarket you're looking at $400 +.
You'll have really great take off with 3.73's, and assuming you have a mostly stock motor, you shouldn't have a lot of traction issues. You can solve those with tire/suspension upgrades as well.
Old Oct 25, 2006 | 03:36 AM
Pat Hall's Avatar
Just make sure to buy a set of 3.73's that are made to fit a 2 series carrier if you plan on keeping the stock posi unit.
MustangBeater20
Oct 29, 2022 09:20 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
Warlocksirix
Sep 3, 2015 12:26 PM
