What type of Flexplate
Old Nov 6, 2006 | 08:02 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Hello,
I am getting ready to buy a flexplate for a 1991 Trans Am. I know I need a 153 tooth flexplate, but should I purchase an externally balanced or internally balanced flexplate? Also, how is B&M for quality?
Thanks!
Old Nov 6, 2006 | 09:33 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
internal, and get one that's SFI approved. B&M is good, but anything with an SFI sticker is fine. should be about $40 on ebay.
Old Nov 6, 2006 | 02:39 PM
wildjyoung's Avatar
Flexplate
Is the externally balanced flexplate for 400 CI or larger?
Old Nov 6, 2006 | 02:54 PM
Car: 1982 Trans Am
Engine: 383 chevy
not necessarily. but if you're running a TPI 350 you need an internal (neutral) balance flexplate for a 1-piece rear main seal.
Old Nov 6, 2006 | 03:46 PM
Flesh&Blood's Avatar
There seems to be a dispute as to what constitutes an externally balanced engine, but the flexplates on 1 piece rear main seal engines are not nuetrally balanced. B&M refers to theirs as externally balanced. At least that's how I read it.
http://store.summitracing.com/partde...5&autoview=sku
" B&M 20238.
Flexplate, 153-Tooth, External Balance, 1-Piece Rear Main Seal, SFI 29.1, Chevy, 5.0/5.7L, "
Old Nov 6, 2006 | 04:06 PM
wildjyoung's Avatar
Flexplate
I looked at the pictures of the neutral balanced flex plate and it has the external weight to compensate for the 1-piece rear main seal. As it was explianed to me from Summit that is all I need to worry about. However, I am still slightly confused. So, I am going to follow the reccomendations in this post.
Thanks for the help!
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
