t5 swap torque converter connector
Car: 85 camaro z28
Transmission: auto to manaul
can i just leave the torque converter switch alone 4 now, or do i need to wire it together?
wire it together
Why would you do that?
Just leave it hanging. It's very low maintenance.
The only wiring you have to be concerend with is the neutral safety starter switch, which used to be on the shifter but is now on the clutch pedal; and the backup light switch, which also used to be on the shifter but is now on the transmission.
Car: 85 camaro z28
i have a check engine light, i thought it was it. mayb its cuz i wired the neutrel safety directly together? hopefuly il have time to tommrow to finish this forever goin project. lol. oh by the way did you change your prom??
ambainb
Apr 25, 2016 09:21 PM
