fix bent shaft?
Old Nov 23, 2006 | 05:59 PM
sLoW'n'StEaDy's Avatar
fix bent shaft?
I have found a T56 trans for a pretty good pirce! However it has a bent shaft. Dont know exactly whats up with it, all it says is "bent shaft"
fixable?
Old Nov 23, 2006 | 08:21 PM
Sure. There's 2 ways to go about it. One has more steps, one less steps.
1. Buy trans with "bent shaft". Let's call this one #1.
2. Buy trans without "bent shaft. We'll call this one #2.
3. Buy rebuild kit.
4. Disassemble both transmissions.
5. Set aside bent parts from #1 trans.
6. Assemble #2 trans into #1 case using rebuild kit (bearings & various other soft parts).
7. Install trans #2 into vehicle.
Now.... explain to us all, the benefit of going through steps 3 thru 7; as opposed to eliminating step 1, starting at 2, then skipping straight from 2 to 7.
Then you'll see why my advice is about to be what you've probably already figured out is the real deal.
Keep looking. We all like to think we can "save the planet" sometimes, one transmission at a time; but the real world doesn't work quite like that. Don't rescue the person with the trashed transmission from taking a financial bath, by taking the bath for him.
Old Nov 23, 2006 | 08:25 PM
Thanks, thats what i figured, but for $300 i figured i would ask...
Old Nov 23, 2006 | 08:38 PM
If the $300 is burning a hole in your pocket, feel free to send it to me, instead of throwing it in the trash.
Which is EXACTLY what buying a destroyed transmission amounts to. You get ABSOLUTELY NOTHING WHATSOEVER of value by buying that, except maybe that wonderful warm fuzzy feeling of being somebody else's "greater fool".
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
dbrochard
Oct 3, 2015 12:43 PM
DARKmj16
Sep 9, 2015 04:07 PM
dbrochard
Sep 7, 2015 09:41 AM
