leaky trans selector shaft seal
Old Nov 20, 2006 | 11:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
My selector shaft seal on my TH350 is leaking. Anyone know how you replace it and who sells that particular seal? Any local parts place, ie autozone, pep boys, etc did not carry the part. What all is involved in replacing it and can it be replaced with the trans in the car still, leaks a puddle of fluid a week sitting in the garage and this winter I'd like to fix it.
Old Nov 23, 2006 | 12:38 PM
xpndbl3's Avatar
Car: 1984 Z28
bumpage...anyone ever replaced one of these before?
Old Nov 23, 2006 | 09:05 PM
CriSSes's Avatar
I've done it on a 4L60E. Got the seal from GM at the local dealer parts counter. Cost $6.50. Drain fluid, drop pan, take off spring with roller. Disconnect shift cable and remove lever arm on shaft. There is a spring clip on the shaft inside the case that must be removed. The most important step in all this is to take a small fine file and deburr the shaft before pulling it out of the case. It must slide out easily. Remove old seal and replace with new seal. Grease seal and shaft and put it back together. Not too bad a job.
Enjoy!!
Old Nov 23, 2006 | 09:21 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto Once the pan was off, it was about a 5 minute job.
Old Nov 23, 2006 | 10:22 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yeah, it is a fairly straight forward removal/replace/re-install procedure. any transmission shop can get you the seal or contact a transmission parts place.
Old Nov 23, 2006 | 10:29 PM
xpndbl3's Avatar
Car: 1984 Z28
good to hear, i'll have to get that done one night this winter when I'm feeling bored.
Old Nov 23, 2006 | 10:32 PM
87zjeff's Avatar
how far are you from cincinnati
duh me....nevermind, i was thinking ohio. somebody shoot me now....lol
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
formula_novice
Aug 18, 2015 08:48 PM
Exxon Limited
Aug 9, 2015 08:13 PM
