park
Old Nov 29, 2006 | 11:23 PM
l2edLine's Avatar
Car: 1986 Camaro Iroc-Z
park
when i put the car in park and its on an incline it starts clicking and rolling, is this a transmission problem or whats the deal?
Old Dec 1, 2006 | 03:34 AM
Pat Hall's Avatar
It can really only be one of two things. Either your shifter cable is slightly out of adjustment, causing it not to fully engage in park, or the parking pawl inside the trans is worn down. The clicking noise you're hearing is the parking pawl clicking against the stops since it's not engaged far enough.
Old Dec 1, 2006 | 07:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
check for loose linkage, it seems to be a common problem
Old Dec 1, 2006 | 08:39 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Never hear of using the parking brake when parked on a incline. No wonder you have a problem.
Old Dec 3, 2006 | 07:55 AM
l2edLine's Avatar
parking brake isnt working as of yet
Old Dec 3, 2006 | 09:31 AM
DJP87Z28's Avatar
Ok, Parking on incline put a strain on tranny.
Old Dec 3, 2006 | 09:44 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i would go with the loose/misadjusted linkage. lots of people rarely use the parking brake and don't have this problem. what is harder on a park gear is putting it into park while the car is still moving.
Old Dec 3, 2006 | 11:47 AM
DJP87Z28's Avatar
People that rarely use there parking brake are the ones with rusted and in-operable cables. Using it on incline is still good advice instead of "don't use it".
Old Dec 3, 2006 | 11:53 AM
87zjeff's Avatar
i agree...i was just trying to help the OP with the more immediate problem
RedLeader289
May 28, 2019 01:47 PM
apie2546
Oct 16, 2016 02:24 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
