tranny please help me
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
im am putting a th350 in my car this sunday.... i know theres probly another thread that tells me how ... but instead of looking thru threads and only getting bits and pieces id rather start another and get all the info i need...
im pulling out my tranny... what exactly do i have to do and in order lol never pulled a tranny before... then im putting in the other tranny
please help
please help
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the th350 is not a bolt-in-and-go swap. you need a swap kit that has brackets for the torque arm as well and other vaccum connection and cable connection, summit and jegs sell them. i think the trans member is the same and the driveshaft should be they same length, i know the trans yoke is correct. you will probably need to re-do the whole speed sensor setup.
have fun!!
have fun!!
ive got the torque arm kit and all the only thing i havent got is the thing for the vacuum.... is it absolutely neccesary to get the vacuum thing and if it is .. do you have the part numberfor it?? ... i also have the Mega shifter from B&M.... will that cable be enough???
Car: 1991 TransAm
Engine: 1969 360 sbc
Transmission: th350
Axle/Gears: posi 4.11 gear
where can i get the torque arm kit for the turbo 350 i need one i am putting one in mt 1991 TA can you give me a link as to where i can find this
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
