28 spline???
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
28 spline???
I always thought the 90-92 cars were the only ones with 28 spline axles, but now I heard that certain f-bodies starting in 87 or 88 got them as well. Is this true or are all 89 and back 26 spline axles?
Car: 88 IROC
Engine: L98 HCI
Thanks.
Do you (or anyone else) know if the axles used in the 9 bolt are the same as the 10 bolt? Are they 26 spline as well?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
9-bolt axles are 28 spline, and they are not the same as 10-bolt axles.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
New 28 spline aftermarket axles which will be better than any factory axle are only about $125 each.
Car: 88 IROC
Engine: L98 HCI
Thanks to all who have responded.
The guy who said some cars had 28 spline from 87-89 must have been referring to the 9 bolt axles. I wasn't aware that they were different, and without the c clip they must be more durable. I will probably just go with new axles right away since I have a new carrier and gear set for a 28 spline set up.
https://www.thirdgen.org/forums/tran...y-carrier.html
See the link to axles that I posted in this thread, about the 15th or so post.
Car: 88 IROC
Engine: L98 HCI
Thanks for the link. It looks like I'll be placing an order with Summit for those axles and an ring and pinion install kit, then I should be set to rebuild the rear end on my Iroc.
codeysabatini
Nov 10, 2015 04:07 PM
Prodigious
Sep 18, 2015 05:23 AM
