T5 2nd gear problem
Car: 1984 Camaro Z28
Engine: 5.7L crate engine
Transmission: 5-spd
Axle/Gears: 7.5 with 3.73
T5 2nd gear problem
I was wondering if anyone else has ever had a problem with 2nd gear sometimes being difficult to engage? Could it be a synchro issue or is it a defect with these transmissions? I'm thinking of basically replacing the synchro's for 2nd gear, unless someone has any other ideas.
Thanks in advance
Thanks in advance
About 99.999% of the time, "hard shifting" is REALLY a clutch problem, not a transmission problem. It might show up as a transmission symtpom, but that doesn't mean you can fix it by working on the transmission.
Now, crashing into 2nd, that might be a transmission problem. But not "hard shifting".
The main suspect would be the pilot bearing.
junkcltr
Aug 2, 2019 11:12 PM
dhonda200
Aug 11, 2015 11:50 PM
