4th gen rear swap help
Old Dec 14, 2006 | 04:14 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
So im going to buy a 4th gen 3.43 posi disc brake rear for my '92 Heritage Edition. I know that it is a direct bolt it, but will someone PLEASEEE tell me how much overall longer is the 4th gen rear vs. the 3rd gen rear!! Ive looked all over and have seen many differnt nubmers, so if someone could tell me an accurate nubmer, that would be great.
Old Dec 14, 2006 | 07:36 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
4" total
Old Dec 15, 2006 | 02:30 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Clearence
Will i have ANY clearence problems at all when i install it???? Please let me know
Old Dec 15, 2006 | 04:55 PM
Zepher's Avatar
Clearance problems with what???
The only issue I can see is if you use your 3rd gen wheels on that axle that they may stick out a bit and rub the fender lip,
this is a 4th gen rear with ARE 16" 3rd gen offset wheels,
And here is a 4th gen rear with my 16" GTA Wheels,
Old Dec 15, 2006 | 10:03 PM
BOTTLEDZ28's Avatar
Transmission: A4
as stated above, you will not have any fitment issues at all installing this. Just make sure you get 4th gen wheels now. thats all. your only other issues will be the brake lines and the ebrake setup. real simple though just read through 12 billion threads there on on here about it.
Old Dec 16, 2006 | 02:25 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
You'll want to make sure to get 3rd gen e-brake cables as well. I got the 4th gen set with my rear, and they don't fit. Here is a shot of my car with the 4th gen rear installed.
PS, the plus with the 4th gen rear is that you can run 17x11s with the right offset and have no clearance issues.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
