ring and pinion markings
Car: 1992 Camaro RS
Engine: 5.7
here a couple a pictures of the ring and pinion markings, whats your comments?
Here's the drive side
Here's the coast side, kinda hard to see..
I'm almost positive the pinion is within .003-.004, i'm gonna check it again tomorrow.
Did I use too much marking compound??
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
http://www.richmondgear.com/ringandpinion.pdf
Pinion is in too far. You'll need to reduce the amount of shim under the pinion bearing to move it outward providing that's a 10 bolt.
"I'm almost positive the pinion is within .003-.004, i'm gonna check it again tomorrow."
you should be 100% positive the pinion is within .000". set the pinion depth, set the pinion preload, set the back lash and the contact patten will be right.
Car: 1992 Camaro RS
Engine: 5.7
Here's some more pictures, pinion is on, dead on. backlash is .008.
I might need to clean off the compound and check it again. ( i didn't take off the old compound)
Pinion is low - pattern is running on the "toe" edge of the teeth.
...oh no, not a gov loc posi
whats wrong with a gov lock? i thought that was better than a cone type
LT1Formula
Oct 8, 2015 08:34 PM
