Need picture of the side of a Zexel Torsen LSD
Old Dec 19, 2006 | 04:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I need to know how many bolts are supposed to hold the carrier together since one or two fell out. I've got 4 in the carrier and one in my hand that is all beat up and a hole in the diff cover, but the hole doesn't look large enough for the bolt to fit through.
here is a pic from torsens' site,
from this angle, I can't tell how many bolts hold the diff together.
Old Dec 19, 2006 | 06:16 PM
MdFormula350's Avatar
https://www.thirdgen.org/forums/part...light=slp+posi
this should help, looks just like the torsen zexel I put in my car.
Old Dec 20, 2006 | 02:18 AM
Zepher's Avatar
thanks.
Ok, looks like only 4 bolts, which are still in there. I didn't notice any ring gear bolts missing, but I'll double check just to make sure.
Old Dec 22, 2006 | 03:05 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
did your 305 munch up a take-off Torsen diff? Or did something else come loose? If you actually broke the diff then I better be careful with mine too!
Old Dec 22, 2006 | 07:10 PM
Zepher's Avatar
Well, I am either retarded or blind (maybe a bit of both ).
I "thought" that I had all 4 bolts on the torsen, but it turns out that I sheared off 2 of the bolts that hold it together and one did go through the TA cover.
This rear was off of a 2001 SS. Rear was all stock except for the TA cover and the Moser Axles I used from my other rear.
I am a little worried that I may have damaged the Torsen by driving it home with only 2 bolts and fliud leaking out, only drove about 5-10mph for less than 3 miles.
I am going to try and yank it out tommorrow if the weather is decent.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Street Lethal
Aug 14, 2015 08:25 PM
Elliswon
Aug 10, 2015 12:33 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
