Please !! How do you bleed a t5?!
Old Dec 23, 2006 | 07:36 PM
Excellegions's Avatar
Car: 91 Camaro TBI 5.0
I've been at it for three weeks now, Some say pump, some say don't pump, bleed screw would bleed pure fluid; no air while pedal is compressed yet still no reponse from the slave cylinder when I press the pedal. I need step by step method of instruction, bleeding for dummies, because Im sure my hands are going to smell like brake fluid for weeks as much as Ive been on this....
Old Dec 23, 2006 | 09:06 PM
player 88's Avatar
Engine: 360 .060 over TPI
1. Fill the clutch master cylinder with fluid,
NOTE: DO NOT LET IT RUN DRY during the bleeding process.
2.There is an allen bleed screw on the slave cylinder. It is right at the front, on top next to the fluid tube. 4 or 5 mm If I remmember correctly.
3.Push the pedal and hold, then crack the screw. then close the screw, then release the pedal and repeat until no air comes out.
NOTE: Don't release the brake pedal with teh screw opne or you will suck air back in.
Just like brakes.
You may need to pump the pedal a couple of times to get fluid into the clutch master cylinder.
Old Dec 24, 2006 | 12:50 AM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
master and slave could be bad. you can buy the whole kit from gm prebleed, no headacks
Old Dec 24, 2006 | 05:08 AM
ede's Avatar
ede
gm way is to do a gravity bleed. i never found it to be real a good method. i use a pheniox injector and do a reverse bleed. take about as long to type this as it does to do the actual work.
Old Dec 24, 2006 | 09:10 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
I just cracked the bleeder screw open and let it gravity bleed. It may take longer but it works!
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
84redta
Sep 19, 2015 09:58 AM
dimented24x7
Sep 6, 2015 03:51 PM
backtothe80s
Sep 5, 2015 12:39 AM
