Shift kit??
Old Dec 26, 2006 | 11:27 AM
GTA_91's Avatar
Car: 1991 GTA trans am
Engine: 305 tpi
Shift kit??
Im looking to improve the performance of my car and I was wonering if this is the right shift kit for my car??
http://cgi.ebay.com/ebaymotors/TransGo-700R4-Transmission-Shift-Kit-81-UP-700-R4-JR-GM_W0QQitemZ8033660775QQihZ019QQcategoryZ33727QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
i also found this one
http://cgi.ebay.com/ebaymotors/TRANSGO-700R4-SHIFT-KIT-CHEVY-MU-T74167_W0QQitemZ320043285196QQihZ011QQcategoryZ33727QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
If these dont work tell me one that does.
And if they do which one is better?
and is that a good price for them??
I was also reading about some "boost valve" for this shift kit.
Is this all that is??
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260032259938&fromMakeTrack=true
Any info would be great.
Old Dec 27, 2006 | 05:41 AM
92 Heritage RS's Avatar
Car: 1992 Camaro RS Heritage
Engine: 305 TBI
Axle/Gears: 2.73 open 28 spline
Hello GTA_91,
I am by no means a shift kit expert, but I did install one on my car with very nice results! I used the Transgo 700-2&3 kit. It has the Competition, heavy duty, off road and pro-street; with Optional stick shift. What that boils down to is this is a serious shift kit with lots of modifications. You don't nescesarily have to take the trans apart but there are a few OPTIONAL items like firmer clutch springs included in this kit that require the trans to be dissassembled. The vast majority of required mods are done in the valve body and the surrounding case area. As long as you keep everything clean and follow the directions closely you should'nt have any problems. I would also recomend going with a corvette servo and a .500 boost valve as well. These all work in unison to give you firm crisp shifts. I just finnished my install over the holiday weekend and it performs amazingly. When I accelerate hard is when it works the best. Because I have an open rear end I do get a jerk to the right when it shifts from 1st into 2nd but all the other shifts are smooth!
Here's one on Ebay! http://cgi.ebay.com/ebaymotors/700R4...QQcmdZViewItem
Good luck!!!
BTW, I also had a problem with the kit I ordered! The kit was a couple of parts short. I called Transgo up and they were very friendly and within a few days I had those parts delivered to me for free!! Very good customer service!!
Old Dec 27, 2006 | 11:43 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
both of those are the same kit, just different boxes. it is the jr. shift kit. not much to it. at least get the one that 92 Heritage RS shows in his post. it is more extensive and has the proper boost valve already in it. what i would do if i were you and didn't work in a tranny parts place is get hold of Dana(Pro Built Automatics) and talk to him. he modifies the 700 2&3 kit. from talking to him, it is a really good kit.
Old Dec 27, 2006 | 10:42 PM
Pro Built Automatics's Avatar
To get the smooth part throttle shifts, you will need the 700-2-3 & the Junior. I combine the two kits, to get the best of both worlds. If you have any questions on this let me know.
Old Dec 28, 2006 | 01:56 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Not to sound like an idiot or anything but what does a shift kit do/modify anyway. I am going to attemt to rebuild my 700r4 that has no reverse at all. And I want to get a rebuild kit w/ a shift kit included. Just wanted to know what they do exactly to see if its worth the extra 50 bucks.
Old Dec 28, 2006 | 03:48 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
^I purchased a modified shift kit from him (Pro Built Automatics), and I am 100% pleased. Under normal driving, the trans feels stock with nice smooth shifts. Get a little heavy on the throttle, and the shifts become more hard/crisp/snappier. When I go wide open throttle, I get a nice hard shift. I got a video in my sig of a before and after. The downshifts are also much harder/quicker/snappy.
Old Dec 28, 2006 | 11:14 PM
Engine: 305 TBI
Well 87CamaroMan, from what I can tell, the modifications to the valve body are intended to increase fluid pressure in certain areas to create firmer shifts. You are actually drilling into key areas of the valve body to allow fluid to bypass into other areas. They also provide different valve springs than OEM to put more or less resistance on specific valves in the valve body. Reprogramming kits like the one I used come with significantly firmer clutch springs to increase clutch pressure as well. It isn't nescessary to use them, but everything works together to provide the performance you're looking for from these kits! I hope this helps you. Good luck!
Old Dec 28, 2006 | 11:21 PM
Okay thanks. Thats what I thought. Just wanted to be sure.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
