What fluid to run after manual trans rebuild?
Old Jan 4, 2007 | 07:53 PM
kaptinkafeen's Avatar
Hey guys,
I just wanted to ask what do you guys recommend for fluid after rebuilding a T5 - regular ATF or synthetic ATF?
Is there any concerns when using synthetic oil in a fresh trans as there are when for example ,breaking in a freshly rebuilt engine? TIA
Andrew
Old Jan 8, 2007 | 11:01 AM
mackdaddy4852's Avatar
Kaptinkafeen
A synthetic will help the syncros seat better.I have put a new syncro in and it still grinds,put a synthetic in and no grind.No damge will happen!
Old Jan 8, 2007 | 09:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Gear Oil for a non-world-class '83-'87 T5, and automatic trans fluid for a World-Class '88-'92 T5. Use synthetic fluid if you want.
Old Jan 9, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There was a lengthy thread about this topic some time ago--and IIRC, no real consensus appeared. For example, the shop manual for my 85 recommends AFT, not gear oil. I'm using Mobil 1 AFT with no ill effects.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
Leggman1
Aug 6, 2015 04:15 AM
