how do i "widen" the gears?
Old Jan 6, 2007 | 02:29 PM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
I dont know anything about trannies really other than they have all the gears and each gear sequential gets small kind of like on a mountain bike. I also know that(through freinds and word of mouth) If you widen the gears you reach higher top speeds but i was wondering how to widen or tighten the gear. And while im at it how do i stop the retarded infinite gear on an auto? You know when it wont change gears because you have the accelerator buried.
Old Jan 6, 2007 | 03:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I assume the 'no gear change' you are talking about, is when it won't do the 3-4 shift at WOT. Thats normal on a 700R4, and I beleive there are certain kits out there to eliminate this, but I'm not 100% on that, as I never looked into it (I perfer the manual trans cars).
As for widening the gear spread, theres very little you can do about that without spending ALOT of coin. The only real option you have is taller (numerically lower) rear end gears. That will give a larger difference between the gears, and could give you more top end speed if you have the power to get there. You'll lose some low speed acceleration by doing this though (how much depends on how much you change the gear ratio).
Old Jan 6, 2007 | 08:36 PM
Car: Fire Red 89 RS
Engine: 2.8L :(
thanks alot for the help i think ill just change the rear gears and i was curious if a new chip would change that stupid issue where it doesnt do a 3-4 change
Old Jan 6, 2007 | 08:58 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
the chip won't help. but i know that you can get a 3/4 wot part from summit racing.
http://store.summitracing.com/egnsea...11460&D=311460
Old Jan 9, 2007 | 05:37 AM
Pat Hall's Avatar
Sounds to me like it's time for you to drop the cash for a nice performance built 700r4. That'll set you back about $600-$1500 depending on who you get one from, but it'll feel like a totally different car with a high performance auto compared to the slushy, weak, stock trans.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
