T-56 6spd for drifting good/bad?
Old Jan 8, 2007 | 04:52 AM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Hey guys I have a 1982 Berlinetta with a turbo 350 in her. Well in the near futior im installing a T-56 6spd and I wanted to know if there any good for drifting. Would it need anything to help it withstand the on and off power that come with drifting?
Old Jan 8, 2007 | 07:34 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm using one with a Spec stage 3 clutch and its working great for drifting, was out there this past weekend in fact. I'm not sure how it would work out with a stock clutch but I know with that clutch it works great, clutch grabs hard, clutch kicks are effective.
Old Jan 8, 2007 | 08:34 AM
Stevo's Avatar
Car: Pair of 92 Z28s
If you want to beat a clutch and never have to worry about it any twin disk should do. No matter what i throw at mine it never starts slipping, itll get more chatter but never stops grabbing. This should just be a question of what is strong enough to drift with, but T56s are pretty strong just they can and do break like everything else, if you were thinking T5 - definently think T56 instead.
Old Jan 8, 2007 | 09:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
t56 is probably your best choice...
the clutch shocks you may give it to break the tires loose will eventually grenade a T5..... and using autos for drifting kinda sucks....
Old Jan 8, 2007 | 11:05 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That is why you make your engine strong so you can just power over.
Old Jan 8, 2007 | 12:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you have enough power to spin the tires, you have enough power to break the T5....
Old Jan 8, 2007 | 01:59 PM
Zepher's Avatar
if the tires are spinning, the T5 is safe.
Old Jan 8, 2007 | 05:28 PM
Car: too many ...
Well, its all relative to the contact patch right? Smaller contact patch and you don't need alot of power. But after drifting with a manual transmission (T56) and comparing to automatic (TH350), I gotta say the manual is much much better. Its harder, but way more fun. You can do stuff you just can't do with an automatic. The only advantage I can think of about the T5 vs the T56 is the weight, what is it a 45-50 pound difference or something? So if the T5 was built w/ stronger gears and case that might be a winner. If it was stock I'd expect it to break. But hey either way, T56 or T5, its gonna be more fun than auto.
Old Jan 9, 2007 | 10:25 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
if you could get a much stronger case, and used stronger gears..... it wouldnt be a T5 anymore... lol.
really, the main problem is the weak case.... when that flexes, everything its holding moves... and then things break.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
dustint209
Nov 26, 2015 12:28 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tonys91rs
Oct 10, 2015 03:31 PM
ULTM8Z
Oct 2, 2015 01:25 PM
