new drive shaft????? help
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
I want to buy a new drive shaft that is made of aluminum for teh lite weight and to remove the vibration i'm getting. Any recommendations of places taht are cheap or god performace? jegs, bbk, etc....
anyone buy one that have any good or bad opinions on it???
any suggestions please.
Axle/Gears: no idea
waste of money as in i shouldnt do it at all or waste of money if i do it from a site?
should the one from 1998 models and up, bolt right in?
Car: 1990 WS6 FORMULA
Engine: LT-1/LT-4
Transmission: 1995 T-56
Axle/Gears: 1995 3.42 Disk rear
drive junk
I noticed a huge diff. when I put the aluminum d-shaft in my 90 the high RPM & speed vibration were all taken care of. I got mine from a local junk yard for $50.00 It was from a 98 camaro ss Thread Starter
Axle/Gears: no idea
ok sounds good but would it hook up or bolt right in with no adapter or whatever needed?
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Cool, I have damn vibration on my ride to...Think it is the shaft......Might look for one at the junk yard.
Engine: LT-1/LT-4
no problem
from 82 to 02 the drive shaft is the same length weather it is a automatic, 5-speed or even a 6-speed there is a dampner on the frount of the factory shaft witch will also help with the rotateing vibs. that the third gens are notorious for. If you can find one for under $200 bucks buy it. If not get one from imperal drive shafts (summit or jegs). Its worth the investment
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the length is different for TH350's. Alum shafts, however, should all be the same length, 41 1/2" from U-joint center to U-joint center. The JG1 alum shaft has a metal label attached with p/n: 10085375. The LS1 shaft is p/n: 12564003. Try the yards. These shafts are more plentiful than people believe (I once purchased and sold 70+ JG1's). The only difficulty I encountered was that the pre-88 cars, including my own, required another U-joint. I used CarQuest #3-3130.
JamesC
JamesC
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I was looking for a used one in exellent condition and they were between 120-200$. Then I found this guy on ebay, he makes you a new coustom aluminium driveshaft for 185$ (+ 45$f for a new transmission yoke that I would recomend).
Mine is 41.5" center to center of the bearing caps. Should be the same size from 82-2002. Only difference the joints size. But the seller new ewerithing I needet.
The 10min. job is easy.
1- Thake out the four bolts holding the C clip to the rear yoke bearing caps.
2- Slide the drive shaft out of the thranmission. Little oil will come out that
is normal.
3- Check the rubber seal on the transmission, if brocken replace. (was in
good condition on mine)
4- Slide in the new driveshaft (if you diden't go with a new transmission
yoke you'll have to take the old one from the old shaft.....better spend
45$ more)
5- Bolt it back to the rear yoke (you may put some locktyte on the bolts),
be carefull to not let the bearing caps fall off wile intalling (a neadle
bearing could fall over).....put some tape.
Sorry for my English.
Link.
http://cgi.ebay.com/ebaymotors/CAMAR...spagenameZWD1V
If two-piece means that you have a V6, yes, the alum shaft will fit. You might consider providing more info about your car in your profile.
JamesC
JamesC
Axle/Gears: no idea
all of this is great guys thanks, but does anyone know for apsolute certainty that a certain year with the aluminum drive shaft will bolt right in place with no modification needed for my 1986 v8 automatic trans am? i jsut don't want to buy the wrong thing and be stuck with a wrong piece and then spend more money on another one playing the guessing game. i might jsut go to that guy who makes them we'll see. i'll also look into some of the post you guys said above about the 98 + years
JamesC
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
[quote=thomas1976;3185128] Then I found this guy on ebay, he makes you a new coustom aluminium driveshaft for 185$ (+ 45$f for a new transmission yoke that I would recomend).
i got mine from him too, but with 1350 u-joints, so i needed a new front and rear yoke. very good quality
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
What about a V6 thirdgen Automatic. Will an LS1 driveshaft fit? I've had vibrations forever, and none of my rims are bent and all are balanced. New tires too! Must be the driveshaft.
Car: 89 RS, 92 Z28
Ok guys, I got mine in, and it cut out ALL of the vibration...It was 75 dollars well spent.....Wish I woulda done it long ago.....I had a guy at the junkyard get on the hotline, and find me one...Had to drive to houston to get it but I sure am glad.....Tom
Axle/Gears: 9-bolt/3.45
Try IROCZDAVE's website below. Scroll to the bottom of the linked page, and you see that he's showing one for sale right now. He's a very good guy to do business with as well.
http://www.thirdgenusa.com/thirdgenusafirebirdparts.htm
He prolly just has the one at the moment(if he even still has it), but he seems to find them pretty often, so keep checking in with him from time-to-time if you don't find one. I've purchased one from him myself, but I've also found one in a junkyard too, so they're apparently not as rare as you'd think. So check your local yards too.
Like Sofa said(meant), spending $300-$400 on a new one from a website is a waste of money, because you can prolly find a good used one for half that or less.
Right: my original post was supposed to mean, except that I wasn't very clear, that buying a "new" one is a waste of money when you can buy a perfectly good used one for as cheap as they are. About $150 usually.
Like LA said, keep checking, if you don't find one right away. Don't be in a big hurry. Being a used part, it's not like somebody can "order" one for you; you just have to be there when one shows up out of a wrecked car.
Car: 89 RS, 92 Z28
Do like I said..There is a nationwide "Hotline" that junkyards use to find parts...Just ask the people to use it for you...There is no cost....Guy in South Houston called for me, and within minutes had located mine...I also found my Posi rearend the same way....save alot of running around....Tom
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Cant find one locally? Pick which one you'd like from:
http://www.tacreationsusa.com
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ozz1967
Aug 16, 2015 10:23 PM
